late midi program change
Home Forums Products Stompboxes late midi program change
    • #167854
      eivaar
        Hi, when I do program changing via midi, it takes some time before the selected programs load, and it takes even longer before the correct program appears on the display. Is it any way to avoid this problem? Is it something I do wrong? (ca 1,5 sec for the program to load, and 13 sec before it appears on the display)
      • #167869
          Can you be more specific with your setup? Is this an issue you are having with an H90? Are you using the latest H90 software?
          What device are you using to send PC messages? Is it only sending a PC message or is it sending other MIDI data at the same time? You may need to use a MIDI monitor to see exactly what is being sent. The PC should happen immediately on the H90 and the display should also change  immediately to reflect the new Program.
