Load Ultratap, Micropitch, Blackhole template card presets onto H9
Home › Forums › Products › Stompboxes › Load Ultratap, Micropitch, Blackhole template card presets onto H9
    • #116658
      jvasiloff
        Has anyone made a file/guide/resource to illustrate how to achieve the Ultratap, Micropitch, Blackhole pedals’ presets (template cards) on the H9? I am not sure if I am asking this properly but essentially I am looking for a file (ideally) that will load the template cards that come with the new(er) seperate eventide pedals… to load these template cards onto the H9.
      • #158684
        jbamberg
          We don't currently have a way to translate the Blackhole/Micropitch presets to the H9.  The algorithms were tweaked slightly for the newer pedals, so it isn't necessarily a trivial exercise, but we understand the value for H9 customers and would like to provide this at some point.
        • #158685
          jvasiloff
            jbamberg wrote:
            We don’t currently have a way to translate the Blackhole/Micropitch presets to the H9.  The algorithms were tweaked slightly for the newer pedals, so it isn’t necessarily a trivial exercise, but we understand the value for H9 customers and would like to provide this at some point.
            Thank you for the reply. forgive my simple interpertation of this as i am in no way an alogrithm tweaker, but to me the easiest route would be to twek the algos in the H9 to match the standalone pedals? i am sure i am oversimplifying this… but it seems the next logical step? anyway thank you for the reply.
          • #158686
            jbamberg
              What I meant was that because of differences in the algorithms, if you were to turn each knob on the H9 to the position of the knob on the corresponding single-algorithm pedal, you might not get exactly the same sound.  You won't even always have the same set of knobs for each algorithm.  For example, the UltraTap pedal has a "Feedback" control which is not present on the H9 version.
              The upshot of this is that it would take some work to derive a set of H9 presets that were identical (or as close as possible) in sound to the standalone pedal versions.
              It is also not really feasible for us to port the standalone versions of the algorithms to the H9, unfortunately.
