Looper continues to play when switching programs
Home Forums Products Stompboxes Looper continues to play when switching programs
    • #191988
      JDrage
        So I have a bank set up with a program which I use to make a loop for the beginning of a song, and a second program I switch to when the drums come in. I have Tails turned off on P A and B. But when I switch to the second program, the loop finishes playing. Is there a way to get it to stop when I switch programs? I see there is Spillover in Global, but that’s… global. I generally want this to be not 0, just in this instance. Shouldn’t setting Tails to Off on the program achieve this?
      • #191989
          Tails will only apply when the Program/Preset is bypassed. If you are loading a new Program without first bypassing the previous one, then Spillover will determine how long the previous Program can still be heard.
          Sorry, but the global tails parameter is the only thing that will change how long it takes for the looper to fade out once the new Program is loaded.
          You may be better off bypassing the first Program, or stopping the loop, instead of adjusting the Spillover setting for this scenario.
