Looping video using the Pitchfactor
Home › Forums › Products › Stompboxes › Looping video using the Pitchfactor
Viewing 5 reply threads
    • #109614
      I made a guitar looping video using a couple of sounds out of my Pitchfactor pedal. Let me know what you think!
      Can't wait to check out the H9 by the way!
      [View:http://www.youtube.com/watch?v=4PrINa362Hs:550:0%5D
    • #124311
      MarcoR
        Sounded great! What looper are you using?
      • #124312
        Thanks! I'm using the Digitech Jamman Stereo.
      • #124313
        Thanks! The looper I'm using is the Digitech JamMan Stereo.
      • #124327
          Nicely done.  It's similar to how I approach the PitchFactor, except I use multitrack recording in a DAW (software) application.  Your timing is very good.  The Digitech isn't locked to MIDI Clock, and that's something that's always held me back from a hardware looper approach.
          Do you use the same hardware setup live with other musicians, and have you found it to cause any timing issues in that situation?
        • #124338
          I do use the same setup playing live with other musicians. Actually the Jamman is capable of generating a click based on the loop that's playing. I can send this signal to the drummer to play along to.
          This only works however when I'm the one starting the song. If I want to make a precise loop mid-song I just hope for the bestSmile
