Mangledverb algorithm (Space Pedal) seems to have low output
Home Forums Products Stompboxes Mangledverb algorithm (Space Pedal) seems to have low output
    • #108757
      davidkaeser
        since I have updated to v4, my patches with the mangledverb algorithm have very low output…
        Is it normal ? Exemple : patch SANSKRITUAL…
        Thanks for reply
        DAVID KAESER
      • #123444
        wedelich
          Hi davidkaeser,
          It's not normal, especially since we didn't make any changes to MangledVerb in V4.  Is the overall output low (both dry and wet), or is it just the wet output that is low?  Has anything changed in your setup since updating?  For example: mono/stereo rig? switch settings on the back of the pedal?  Expression pdl or lack thereof? Etc.
        • #123445
          davidkaeser
            Thanks for your help. I think I found a solution. I have done a reset and then I entered manually parameters (user patches). The problem happened when I used Factor Lib to restore patches.
            Now, no problem ! Thanks again !
            DAVID KAESER
