Micropitch Effects Loop Question
Home Forums Products Stompboxes Micropitch Effects Loop Question
    • #190253
      kisschicken
        I have a Micropitch pedal and running into issues with stereo when using the effects loop. In input one, i have the signal coming in from the send of amp 1 (a marshall DSL40CR). Output one goes to the DSL’s effects loop return. That all works great. Output two is going into a Marshall SC20C’s effects loop return. It works but it’s SOOOO much louder than the DSL. Is there any way to fix this? Thanks!
      • #190259
          It is hard to say if the volume difference is caused by the MicroPitch, the difference in volume may be due to using different amps.
          Are you able to try a different stereo guitar pedal with the same routing and do you still get the volume mismatch?
          The MicroPitch input switch should be set to mono for this setup, please make sure it is set that way.
          • #190262
            kisschicken
              Hi tbskoglund. I think you’re right. I’ll try different combinations of amps. Thank you!
