MicroPitch Input/Output
Home Forums Products Stompboxes MicroPitch Input/Output
Viewing 3 reply threads
    • #116426
      Question(s) for the forum – what exactly do I get if I plug a standard TS cable into the input of the MicroPitch and the come out of both Output 1 and 2?
      If I have the little switch on Mono, am I getting two, Mono output signals? What if I move the switch to Stereo while using the TS input?
    • #157541
      joecozzi
        Guitarfly025150 wrote:
        What exactly do I get if I plug a standard TS cable into the input of the MicroPitch and the come out of both Output 1 and 2?
        You get stereo sound. When switch is set to MONO, but both outputs are hooked up, you get stereo. Same with stereo in stereo out obviously.
        Again, as long as both outputs are connected, you’re outputting in stereo, not dual mono. If you move the switch to stereo while only hooked up with a TS cable, you’re going to be missing right channel information and the pedal will not sound right. With this incorrect wiring, you’d have to move the Pitch Mix knob to one side to get any semblance of normal operation, but it would be mono and again, you’d be missing the processing of one of the voices.
      • #157542
        joecozzi
          To elaborate on hooking the pedal up in stereo, while it was designed for mono compatibility, it really shines when run in stereo. The perceived width this algorithm generates is the stuff of magic, in my opinion.
        • #157543
          Thanks so much for the responses!
