Micropitch no signal output 2
Home Forums Products Stompboxes Micropitch no signal output 2
Viewing 3 reply threads
    • #190788
      Hurlessgtr
        Hello everyone, for some reason my Micropitch has no signal on out #2.  When I used it two days ago it was working fine, but this evening this problem occurred and I do not know why. I have made sure the it is set to stereo output and I have eliminated all other reasons. All my cables test properly and the TC Flashback II, and the MXR Reverb are working. All suggestions and ideas are welcome.
        Robert
      • #190799
          Sorry to hear you are having issues. Can you please provide more details about the entire signal flow before and after the Micropitch?
          Do you have the input set to mono? If the input is set to stereo and you are feeding it a mono signal, you may experience the issue you describe.
        • #190807
          Hurlessgtr
            DOH!!!!!! I did have the switch set to stereo, I don’t know why I did that. Everything works fine now. It’s always some little thing, isn’t it.
            Thank you,
            Robert
          • #190811
              Glad to hear that fixed it!
