MIDI Clock Sync with multiple stompboxes?
Home Forums Products Stompboxes MIDI Clock Sync with multiple stompboxes?
    • #111945
      Fleece
        I use Logic Pro X to send MIDI Clock to my Pigtronix Infinity looper, and it works great.
        I recently added a Space and an H9, and want to sync all 3 boxes to Logic's MIDI clock.
        Because the Infinity only has MIDI IN, my MIDI chain needs to follow my signal chain:
        H9 > Space > Infinity
        I must be missing something, because MIDI Clock isn't making it to the Infinity (which is my first priority). Is there any reason this shouldn't work, or is there a hidden setting I'm missing?
      • #126728
        Fleece
          Just want to add that I have both Eventides set to MIDI thru, and have triple-checked my connections. 😉
        • #126731
            That's puzzling.  I run a Sonar or Lexicon MPX-1 MIDI Clock through a PitchFactor -> H9 -> MIDI Thru -> ADR III & EHX 8 Step Program.  I thought your problem might be one of the MIDI -> CLK OUT set to On, but it doesn't seem to affect pass-through of the MIDI Clock (with MIDI -> OUTPUT set to THRU).
            I also tried toggling the MIDI -> CLK IN settings to OFF, but again, the downstream clocking didn't seem to be affected.  (Of course, the local device doesn't track the MIDI Clock in that scenario).  I connect the live rig to the studio operations through a MIDI router, so let me double-check my findings for any missed Merge routings.
            FWIW, the newer PF firmware flashes "CLK IN" when it's not receiving MIDI Clock.  That may help with diagnostics.  I haven't seen that feature in the H9.  MIDI Channel setting won't affect Clock.  MIDI BPM seems to update very quickly on the Eventide displays with newer software revisions.  I've never had to mess with the CLK FLT position, but that's about all I can think of that's left.
