MIDI hub for Dot9 pedals ??
Home Forums Products Stompboxes MIDI hub for Dot9 pedals ??
Viewing 5 reply threads
    • #164716
      providenceH
        Hi
        will the Strymon Conduit MIDI Hub work with a Micropitch and Ultratap pedals (or are there better ones)? Id like to send commands with a HB MP-100 controller to both…
        Thanks for your reply
      • #164717
        joecozzi
          Yes, the Strymon Conduit will work with Eventide dot9 pedals. It’s highly configurable.
        • #164718
          providenceH
            thanks
          • #165016
            providenceH
              Hi Joe,
              very sorry to bother again but before purchasing (its still a 120+ money device)… do the “Strymon MIDI-EXP Cable” work as connection from the conduit to the Dot9 pedals for midi commands?
              Thanks again
            • #165018
              joecozzi
                Hello providenceH,
                We’re happy to help, always. I have not tested Strymon’s MIDI-EXP cables specifically for when you want to go out of the 5-pin DIN instead of the TRS outputs. I’ve only ever tried the Disaster Area Designs 5P-TRS going out of a Morningstar MC6MKII. If you want to be sure, I suggest consulting with Strymon’s support.
              • #165019
                providenceH
                  ok, thanks!
                  PS I think Eventide should consider providing something like the Conduit 😉
