Midi program change problem
Home Forums Products Stompboxes Midi program change problem
Viewing 4 reply threads
    • #107302
      I have a problem when I change the preset  with a midi pedal board.
      I have a TM, a PF and a MF. They are in chain with midi cables, every factor
      have a different midi channel.
      Sometimes when I change a preset, the third pedal in chain load
      a wrong preset.
      I change cables, midi pedal board and the order of stompboxes
      but the problem still remain.
      Have you solutions?
    • #120816
        Make sure (obviously) that the first two are set to MIDI THRU.
        Less obviously, make sure that they also have MIDIclock out turned OFF.
      • #120818
        Thanks for reply.
        The pedals are set to MIDI THRU, and I almost sure that MIDIclock out is OFF, I'll check it as soon as possible.
        Are there another suggestes?
      • #132046
        Ok I checked the settings…..
        The pedals are set to MIDI THRU and Midi Clock out is Off.
        I have a friend that have the same pedals, and same problem. Also I knew a person in another guitar's forum that have MD and PF and a third stompboxes(another brand) with midi in/out, he has the same problem …..
        Could you check this situation? I think that there some bug or problem on midi
      • #132065
        Have you tried?
