Home › Forums › Products › Stompboxes › Midi settings
January 25, 2017 at 10:03 pm #113980
Send2george2
MemberLike a few on here I’m a bit of a noob on midi. Can someone tell me what I should set my h9 to please?
Here’s my signal chain
1) guitar in to boss es-8
2) midi out of es-8 to midi in of H9.
3) midi out/thru to h&k grandmeister 40 amp in.H9 on midi channel 1
Boss es-8 set default to midi outI send pc messages to h9 on channel 1 and I want to send pc messages to the gm40 on channel 2.
Should the h9 be set as transmit, thru, thru +c or merged?
January 26, 2017 at 2:25 pm #145587
ReverendLove
ParticipantYou should set the following MIDI options in the system menu
Transmit should be Ok.
Then:
RCV CH to 1 or OMNI
XMT CH to the receive channel of the GM (probably 1)
PGM XMT to ON
January 26, 2017 at 3:34 pm #145589
Send2george2
MemberThank you for your response. I can’t see those options on h9 control. I can only see that it allows me to define the midi receive channel which is set to ch1.
Under midi settings I have, midi receive channel, assign midi cc messages to pedal functions, program change receive map, midi clock, midi output mode, midi over Bluetooth.
I am looking in the wrong place?
January 26, 2017 at 4:15 pm #145593
gkellum
ParticipantSend2george2 wrote:Thank you for your response. I can't see those options on h9 control. I can only see that it allows me to define the midi receive channel which is set to ch1. Under midi settings I have, midi receive channel, assign midi cc messages to pedal functions, program change receive map, midi clock, midi output mode, midi over Bluetooth. I am looking in the wrong place?Some of the settings that he mentioned are available on the H9 in its system settings screen but not in H9 Control. XMT CH and PGM XMT aren't in H9 Control. If you check the user manual of the H9, it explains how to navigate to and adjust those settings on the H9.
We've been meaning to add support for those settings in the app, but they're used so infrequently that it's never risen to the top of our todo list.
January 26, 2017 at 4:44 pm #145596
Send2george2
MemberGreat stuff thanks. I’ll look closer. Many thanks.
January 26, 2017 at 7:03 pm #145599
Send2george2
MemberAll setup via the system menu. Thanks guys great support.
