Midi sync timefactor + strymon timeline
Home Forums Products Stompboxes Midi sync timefactor + strymon timeline
    • #111660
      Hello!
      Does anyone know if this is possible? I did try but with no success. In particular I wonder if there's a way to sync looping between the 2 but also delay time. I want to be sync'ed up with an other guitarist who uses the strymon delay.
      Cheers
    • #126021
      gkellum
        Well you could send or receive MIDI clock from your TimeFactor and use presets with tempo mode enabled so that the delays are note values that are relative to the MIDI clock.  I don't know the Timeline; you'd have to talk to your other guitarist about whether it supports MIDI clock and something like tempo mode.
      • #126025
        Thanks. I've actually done some research and probably the reason why my previous attemp failed is that the timeline can only be the slave and probably the midi values on the timefactor need to be changed to match the timeline…
