Midi to control pre/post signal routing?
Home › Forums › Products › Stompboxes › Midi to control pre/post signal routing?
Viewing 4 reply threads
    • #113562
      The manual says I have to set pre and post in each preset.  is it possible to change this with Midi?  i.e. if using a preset can I send a midi message to change the pre/post setting without changing the preset?
    • #143810
        Sorry – not at present. The routing is a feature of the preset.
        • #145966
          Ryan Harris
            I have all of the factor pedals (plus an additional timefactor) and use them on a table in a live setting. I would like to also be able to toggle the preset between pre and post via MIDI because it is cumbersome to do so manually on-the-fly. Per the manual:
            When in PRE/POST mode, you can pick from the above options:
            1) Press and hold the Left Footswitch. The display will show the Output Level.
            2) Press the Encoder until the display shows PRE (default) or POST.
            3) Turn the Encoder to set it as desired.
            4) Release the Footswitch – the Preset will return to its previous Active or Bypassed state.
            5) Remember to save the preset, or the change will be lost.
            I think a CC would be the best way to do this. It wouldn’t impact the current functionality because the preset could still store the initial routing value. Could you possibly discuss with a developer to have it added to the feature request list?
        • #145039
          Jop vS
            That’s a pity, would be great for my setup as well.
          • #145970
            Yeah, it would be nice to have that (and a lot more) parameter in the CC table.
            As a workaround, just duplicate your preset, one with pre and the other one with post.
            • #145973
              Ryan Harris
                Great idea. Thanks for the tip!
            • #145984
              Adamixoye
                MIDI control for this and the input source (guitar/bass/synth) are the two MIDI features I’d really like to see implemented.
                • #145985
                  Ryan Harris
                    I’m using pre.post in a rather unconventional way. I’m running a guitar through the pre i/o and a synth through the post i/o. Being able to switch the input source and the routing at the same time would be awesome.
