Missing global Output Level on H9
Home › Forums › Products › Stompboxes › Missing global Output Level on H9
    • #112321
      hello  H9 community,
      i miss a global output volume control. Is there a possibility  that i can adjust for all Presets  the output level at once?
    • #127499
        Not at this time. We are considering adding a global gain control in some future (undated) release.
        • #141581
          I wonder when this will become reality. I really need that too. for some reason the output level of my 2 h9 pedals is pretty low compared to other pedals.. Or is there any trick I do not know?
        • #141582
          gkellum
            Well, you know that you can assign the output gain to an expression pedal or MIDI right?  But this only takes you up to unity gain.  It sounds like you want to boost the global output level…  You could turn the preset output gain up in each preset you use…
          • #146775
            Did anything happen to global gain control?
          • #146776
              There has been a global swell control for a while. Look at the UM.
              But, note that this îs attenuation only – it acts like a volume pedal.
