Modfactor Adds pop noises to the signal
Home › Forums › Products › Stompboxes › Modfactor Adds pop noises to the signal
    • #112191
      Hello.
      I own a Modfactor. I have noticed that after the unit is on for about an hour or more, there are pop noises added to the sound. sort of short ticks that occur every few seconds.
      It doesn't show any unusual thing.
      It occurs in all the algorithms, most evidently in the less-filtered and more neutral ones.
      The problem remained through all the version updates I have made.
      Any Ideas?
      Thanks In advance,
      Yair
    • #127232
        These pops could have many causes. Things to try:
        Do you get them with nothing plugged into the unit ? If so, try a different power outlet.
        If you only get them with signal, it may be a hardware problem.
         If you still get them, contact support@eventide.com.
