[Modfactor] Depth & Intensity
Home › Forums › Products › Stompboxes › [Modfactor] Depth & Intensity
    • #107603
      Hi there,
      I'm (still) a little bit confused about the exact difference between Depth and Intensity. Can someone explain to me in a few words where the difference lies in the effects ? I'm using mainly Phaser/Chorus/Tremolo, so feel free to concentrate on those 🙂
    • #121482
      Essentially , the depth controls how much the oscillator modulates your signal, and the intensity can be looked as a dry/wet   mix knob. However the functions are different in the Tremolo pan settings.
      So even if depth is 0 , there is still some some effect in the output (except tremolo) , but if intensity is 0 you would get a complete dry signal at the output.The manual explains these knob functions on every algortihm so that should make things more clear.
      Hope this helps.
