Newbie With First Expression Pedal
Home Forums Products Stompboxes Newbie With First Expression Pedal
    • #114095
      I received a Mission Engineering EP-EV expression pedal for my 65th birthday to use with my Modfactor.
      The problem is, I have no idea how to install it. Any thoughts would be greatly appreciated as I don’t have a clue other then the pedal plugs in to the back of the Modfactor. I would like to know if it should go anywhere in a pedal chain or does the guitar run into the pedal and then into the chain. Thanks very much.
    • #146032
      gkellum
        The expression pedal plugins into the back of the ModFactor.  Once you've plugged it in, you should hear a difference in your ModFactor presets by just moving the expression pedal back and forth, since all of the presets should be programmed already to respond to an expression pedal.
        I'm not sure if I'm understanding you correctly, but there's no way to plug a guitar or other stompbox into the expression pedal.  You just connect the expression pedal to the ModFactor or any other stompbox you'd like to use it with.
