Newfangled Saturate won’t show up in Ableton 12 no matter what I try!!
Home Forums Products Plug-Ins Newfangled Saturate won’t show up in Ableton 12 no matter what I try!!
Viewing 4 reply threads
    • #190099
      SenPi
        ok, I am incredibly frustrated at this point because I feel like I’ve tried everything I possibly can, and have gotten absolutely nowhere.
        My setup:
        Ableton Live 12 Suite v12.1.11
        Windows 10 64-bit, build 19045.5737
        iLok License Manager v5.10.1
        Steps I have taken:
        – Paid for plugin
        – Downloaded latest version from website (v1.13.9)
        – Installed plugin
        – Opened Live and clicked “rescan”
        – plugin shows up in the little info bar at the bottom showing that it is being scanned
        – iLok licenser pops up, and I put in my info and it says it has been activated (also shows as activated for this machine in the ilok license manager)
        – Once plugins are re-scanned, saturate does NOT show up in my plugin list
        – Tried uninstalling, re-installing, restarting, turning on/off plugins, re-scanning, deep re-scanning, moving the plugin out of the nested folder, attempting to use the vst2 even.
        – Downloaded OLD versions of the plugin (v1.10.0, v1.11.0, v1.12.0, v1.12.7, v1.13.0, v1.13.2)
        – NONE of them show up in ableton
        – Attempted to run Audacity to see if it works there, but audacity even tells me it can’t run Saturate for whatever reason
        – Have no other daws to test with
        – Emailed Eventide support, and after 1 day they responded, telling me to do the things i’ve already done.
        – Did the things they asked, verbatim, still the plugin doesn’t show up
        – Emailed support back saying that didn’t fix my issue, and I have not heard anything back for multiple days.
        I’m at my wits end, I just want to use this plugin i’ve paid for, but literally nothing I do is letting me use it. Is there anybody here that can actually help me get this working?
      • #190121
          Hi there,
          Sorry to hear you are still having issues. We’re looking into this and will help you troubleshoot it further via the support ticket.
        • #191835
          thatoneguy024
            I am also experiencing this.
            I know you guys are great, but this is total bs.
          • #193809
            captcoolthe3rd
              Hey y’all – here’s a fix I found you can do after installing.
              Go to Computer > Macintosh HD > Library > Audio > Plug-Ins > VST / VST3
              You’ll find a Newfangled Audio folder. Pull its contents (a vst or vst3 file) up outside of that folder, directly to the VST / VST3 folder. Then rescan plugins or close/open Ableton, and it should show up then.
            • #194875
              Lamatron
                This just happened to me and I got it fixed. The issue for me was there is no option to install it to your custom vst3 folder. it installed the plugin to a default location • c:\Program Files\Common\VST3\Newfangled Audio\<Plug-In Name>.vst3
                move the vst file to your custom folder and rescan.
