Nice Tricerachorus Flanger
Home Forums Products Stompboxes Nice Tricerachorus Flanger
    • #177153
      Hermetech
        Been using this subtle flanger preset I created when Tricerchorus came out for the H9, recently got an H90 and it’s working lovely there too. The trick is having the Chorus rate 0.10 Hz and the Detune L1 R-1 going at the same rate (once every ten seconds). You can have just one or the other obviously, but blending both at the same rate sounds really nice.
      • #177167
          Nice work.  I’m often guilty of parameter overload when it comes to presets, but this one shows that sometimes less is more.  Thanks for sharing.  Props for centering the chorus, with a slight spread on the detuning.
          What are you pairing it with in the H90?  My first thought was modulation after a blooming reverb, but the possibilities are many.
        • #177173
          Hermetech
            Thanks. Yeah often simple is best for practical/recording use etc. I’m mostly using this patch with mono guitar so haven’t heard it in stereo for a year or more!
            Right now it’s on the pedalboard and I’m working on a Shoegaze track with a load of other nice chorus effects, with this at the end of the chain for subtle Flange, but now it’s in the H90 I’ve been pairing it with the SP2016 Reverb after, just subtly. All goes into the 4w 5F1 Champ clone I built last summer. Will get around to using the Inserts to send stereo to the ATC monitors as well at some stage, for a nice W/D/W rig.
