No connect with Timefactor under Windows 7 64 bit
Home Forums Products Stompboxes No connect with Timefactor under Windows 7 64 bit
Viewing 5 reply threads
    • #106896
      Impossible to connect my Timefactor under Windows 7 64 bit – failure of driver installation.
      Can you help me?
    • #120045
        Sounds like a problem with your computer – sorry, beyond our control.
        TF does not need any extra drivers – it uses those provided by the OS.
      • #120054
        For what it's worth, I just got my TimeFactor in the mail yesterday (and loving it!!!), but was able to connect with no problems to my Dell XPS m1730 running Win 7 64 Bit.  What kinda computer are you runnin'?
        Later – Mike
      • #120056
        Let me clarify…  I am able to do the USB updating of the firmware, but have been unsuccessful at pulling the presets off of the unit to back them up.  I have an M-Audio Uno MIDI to USB device that I will attempt to do this with later and report back…
        Later – Mike
      • #120064
          Some of the M-Audio adapters use Windows' built-in MIDI driver ("class compliant"), which had problems in earlier versions. M-Audio used to supply a better driver for Windows – don't know if they have one for W7 yet.
        • #123769
          Same problem, here.
