Omnipressor (plugin) attack issue.
Home Forums Products Plug-Ins Omnipressor (plugin) attack issue.
    • #190850
      IgsFi
        Hi! :I
        Does anyone can confirm, that Omnipressor’s attack (transients) really should sound different with every single hit. I’m using it on electronic drums.It is a fabulous compressor, but this part makes it almost unusable if you want a stable static kick. This is my only compressor that does this.
      • #190851
        IgsFi
          Here is a example. Second file is a bit longer. Doesn’t sound good in a mix too.
        • #190878
            I see you have opened a support ticket. Please provide a dry example of your audio along with a preset or screenshot of your Omnipressor settings and that will help us troubleshoot the issue.
