One expression pedal to control 2 Factors: TF (ch1) and MF (ch2)
Home › Forums › Products › Stompboxes › One expression pedal to control 2 Factors: TF (ch1) and MF (ch2)
Viewing 0 reply threads
    • #112741
      I tried to set up one expression pedal with both eventides and I managed to control both expressions with outputs in Omni.
      But, as I use ch1 (TF) and  ch2 (MF) with my Decibel Dr. Switch,  I still need  the output on Thru, and in this way I cannot use XMT and CC to control the expression pedal.
      Is there something I am doing wrong on the setup… or simply you cannot control with one expression both pedals using ch1 (TF) and ch2 (MF).
      Hope someone can help!
