Outputs 1 & 2 – True Stereo or Wet/Dry?
Home Forums Products Stompboxes Outputs 1 & 2 – True Stereo or Wet/Dry?
    • #160932
      esowden
        I don’t see a way to search the forum so forgive me if this has been covered previously.
        I just received my TriceraChorus and UltraTap pedals.  The documentation lists the outputs as stereo, is there a way to set the outputs as wet/dry?  I’m wanting to build a wet/dry rig and need to know as this will determine what I’ll need to move forward.  The chorus will be used before the delay.
      • #160933
        joecozzi
          Hello, there is no wet/dry configuration on the outputs of our “dot9” family of pedals. Only our H9 Max can do that. You’ll have to find an external way of routing your rig for this. However, you can put the pedals in “kill dry” mode and direct that signal to your wet amp.
        • #160935
          esowden
            Just the information I needed.  Thanks!
