PichFactor Midi
Home Forums Products Stompboxes PichFactor Midi
    • #112356
      G'day the midi clock in the Pitchfactor seems to not to be able to register
      Since I last updated –  Harpreggiator refused start the pattern with tempo on then things have got worse as now it (PF) doesn't even register midi tempo now, other pedals are OK (TF, Space) and are after PF in midi chain
      Soz for post not being clear am still confused as to whats going wrong, heaps of ghosts in my PF
    • #127563
        Muzza, you'll have to provide a little more information here.
        Is the PitchFactor your source of MIDI Clock, or is it generated from another source?
        Are you saying that the TimeFactor and Space work perfectly with MIDI Clock, and are connected in a MIDI IN-OUT daisy chain like:  PF  ->  TF  ->  Space?
        Are you using the H9 Control application via USB?
        Have you changed anything in the PitchFactor Pedal / System settings recently, or updated the firmware version lately?  What version do you have in each of those Stompboxes (especially the PitchFactor)?
