Pitch Factor dull tone
Home Forums Products Stompboxes Pitch Factor dull tone
    • #109390
      DavieB
      Hi, I've noticed that the Pitch Factor is tonally dulled when using the Diatonic / Quadravox algos.  When compared to HArpegiator which is clear as day.  Compare the two and sweep the mix from dry to wet and you can hear the tone get sucked out when using DIatonic / Quadravox.  Anyone else noticed this?
    • #124104
      Imerkat
      not at all…you should make a loop then record it with and without the PF. I did this to disprove to myself that there was a difference in the A/D converters, different PF versions, and tracking. Otherwise, there isn't anyway to objectively comment on this
