Pitchfactor cracklings noise
Home Forums Products Stompboxes Pitchfactor cracklings noise
    • #115458
      beedoola
        About a month or so ago my PF started to make some random crackles and pops. After reading around I tried to do a firmware update, and I switched the bypass to relay/true bypass. This solves the issue for bypass but the noise is still there for the effect signal.
        Is there any other suggestions here?
      • #152474
          It is probably a bad memory chip or a faulty connection (bang the unit and see if it changes).
          If so, it will have to come in. Sorry.
        • #152475
          beedoola
            I have also unplugged the ribbon cable twice and that has helped for a short period of time.
          • #152480
              That does suggest it is a bad connection in or to the ribbon. You could try and have a tech replace the ribbon or send the unit in (sorry).
