Pitchfactor – creare your own Harpeggiator patterns
Home Forums Products Stompboxes Pitchfactor – creare your own Harpeggiator patterns
    • #108129
      Is it just me, or do others find it incredibly short sighted that there is no way to create your own Harpeggiator patterns for the Pitchfactor?  I don't understand why we can only choose from what is available via factory presets.  Wouldn't it be feasible to create an application with a pattern editor just like Moog has with their Midi-Murf?
    • #122712
        That would be a cool & very useful feature.  My speculation has been that the preset patterns were 'stuffed' into individual bytes of memory for efficiency.  Perhaps the overhead of having each of the 16 steps programmable was a design decision that hit the cutting room floor.
        Quote:
        … there is no way to create your own Harpeggiator patterns for the Pitchfactor?
        Actually, there is, but it requires sequences of MIDI CC values from an external source.  Each interval of the HarModulator's six octaves responds to a narrow slice of the 0-127 range.  Stack up the correct values in tempo-sync'ed sequence for a custom "HarPeggiator" pattern.
        When using the H910/H949 algorithm [Scale/Speed: Normal] as a CC target, it's possible to program 'glides' into individual steps (found in many of the 26 preset HarPeggiator pitch sequences).  Of course, these workarounds won't have the effect sequences, but the rhythm / groove and dynamics are 'programmable' as part of the MIDI CC sequence itself.
      • #122725
        Imerkat
          hmmm…If i could chime in sequencing in the Pitchfactor I find it challanging but FUN!!! it's an instrument in and of itself. If you look at it with this mindset you'll be rewared dearly! I've said it before- The PitchFactor is a peice of Art!
