Pitchfactor Digital Noise
Home Forums Products Stompboxes Pitchfactor Digital Noise
    • #109113
      freqwfilter
        I'm having a digital noise issue, it sounds like the PF is harmanizing a 60HZ hum. Any ideas?
      • #123835
          It might be an actual 60Hz hum, probably caused by a ground loop or a bad power supply.
          If you're not using the supplied power supply, please do.
          Otherwise, disconnect all inputs and see if you get hum. If you do, it could be a fault.
          You probably won't, in which case plug a guitar directly into the unit. If you still get the hum, it is something at your end.
