PitchFactor MIDI Master Clock Sync
Home › Forums › Products › Stompboxes › PitchFactor MIDI Master Clock Sync
Viewing 4 reply threads
    • #109123
      I have my PF set up as the master MIDI clock in my effects chain. Along
      with the PF, my MIDI chain includes a Line 6 M13 and a Yamaha drum
      machine. I have the MIDI chain set up so when I step on a foot switch on
      my M13, it changes presets on my PF.  This part is working great.  The
      problem is that the PF does not appear to transmit the new MIDI clock
      setting because my drum machine does not change tempo.  But when I use the Tap Tempo foot
      switch on the PF to change tempo,  the tempo changes correctly
      on the drum machine.  I have checked and rechecked my settings and I think
      I have everything set up according the the manual.  Is this functioning
      as designed or am I doing something wrong?
    • #123844
        Do you have the latest software ? There was a bug like this in older versions.
        V3.5.0[4] – see support page for info.
      • #123901
        I downloaded the latest update but the problem is still there.  Please help.
      • #134935
          Is Global Tempo on (UM p.45) ? You would probably want it to be off.
        • #134936
          Global tempo is off…so the problem persists.  Can you duplicate this issue?
