Pitchfactor not saving some midi transmit cc settings
Home › Forums › Products › Stompboxes › Pitchfactor not saving some midi transmit cc settings
    • #107760
      I've had a PF for a while and I just got an MF. Great combo for bass and I'm having loads of fun. One problem though: I'm using an aux switch and exp pedal with the PF (2.3.0[2]), then running a midi cable to the MF (3.0.0beta[0]). The exp pedal and tempo sync work fine, but every time I turn on the PF, the xmt cc channels for tip and ring are set to no channel (I usually run them on c1 and c2). The MF is still set to receive these, so all I have to do is reset the xmt cc on the PF, but it's annoying to have to do this on every start up.
      Support is pondering this right now, but I figured I'd see if anyone else has had this problem and has suggestions or a proven method to fixing it.
      Thanks in advance.
    • #121834
        Sounds like either a power supply problem or a hardware problem. Probably best leave it to support.
