Pitchfactor pedal question
Home Forums Products Stompboxes Pitchfactor pedal question
    • #116566
      inbal dushy
        HI there
        The flex button has a specific and fixed modulation to each bank?
        or I can change the effect that this button does?
        thanks
      • #158193
        joecozzi
          The flex button is actually a performance switch and it’s function changes depending on the algorithm. It cannot be customized. To learn what this button does for each algorithm, you can use H9 Control or you may find out by reading it on the algorithms page of our website. Down at the bottom of each page, there’s a description of each parameter.
          https://www.eventideaudio.com/products/algorithms/index
