PitchFactor, PitchFlex, and Expression Pedal Programming
Home › Forums › Products › Stompboxes › PitchFactor, PitchFlex, and Expression Pedal Programming
    • #107963
      I want to use my expression pedal to control the Pitch mix on the PitchFlex effect, but the effect pedal programming doesn't seem to work on this effect. The expression pedal programming works on all the other effects with no issues.  Is this a bug or is it functioning as designed?
    • #122337
      wedelich
        Hi bwheat,
        I'm pretty sure it is functioning as it is designed.  The expression pedal on that algorithm is only for pitchbending.  You could program an aux switch for Mix if you wanted.
        -Russ
