Pitchfactor USB issue
Home › Forums › Products › Stompboxes › Pitchfactor USB issue
    • #141915
        If you get hum when USB is plugged in, this is probably a ground loop.
        The first thing to do is to make sure that your computer is plugged into the same outlet as your amp.
      • #113113
        I am running the latest firmware. using with a MAC mini.
        When I plug the USB cable in the pitchfactor now seems to alter a load off settings and then won’t produce a wet signal. Bybass is fine.
        The App still sees the Pitchfactor and changes algorythms but there is never any wet sound.
        When plugged into the usb, it sounds like a lot of extra hum is generated.
        Same into an amp or into a DAW
        If depressing for tunner with flex/fs2, display just says Tuner, it never actually goes to the tuner.
        Is this a known issue? Any fixes?
