Home › Forums › Products › Stompboxes › Populating H90 with locked program lists
- This topic has 4 replies, 3 voices, and was last updated 3 months ago by
RobCrowdy.
August 3, 2025 at 9:07 pm #191368
Hi-
I would like to use H90 Control to populate my H90 with lists like “Bass and “Ambient”.
I can see how to create new lists and move programs into them but not just “copy” one of your lists into the pedal.
Is this possible?
Thanks- Rob.
August 4, 2025 at 10:12 am #191380
It’s not possible to copy a Factory list to a User list slot.
If you go to the Program Library you can use the filters to view Programs in the Bass list for example, and then drag+drop them into your currently selected list. See #1 here: https://cdn.eventideaudio.com/manuals/h90/1.11.4/content/h90-control/program-library.html
August 4, 2025 at 10:37 am #191383
Hi Rob,
Lists like “Bass” and “Ambient” are already on the pedal. If you go to PROGRAMS, the first quick knob can be used to change the List option on the display to any one of these lists. Then, with the SELECT knob you can navigate along those factory lists. They automatically load when you browse through programs. However, if you wish to navigate those programs using the onboard footswtiches you must copy those programs into a Playlist, and there is no fast way to do that. I find the easiest thing to do is copy factory programs into the Playlist using H90 Control:
- Start a new Playlist and name it.
- Click Lists in the Program menu and choose the list you want
- On the Playlist, click on the Program number so it highlights in gray.
- On the factory program list, Click & Drag (not click, then drag) the Program from the factory list into the position you want.
This Playlist will now automatically appear in the pedal’s Global Playlist options.
August 4, 2025 at 8:15 pm #191390
Thanks Eventide people- that explains things very well- especially the relationship between Control and the pedal itself.
Cheers-
Rob.
