power question …timefactor
Home › Forums › Products › Stompboxes › power question …timefactor
Viewing 3 reply threads
    • #107718
      Can I plug my timefactor wall mount into the courtesty outlet on the back of the voodoo lab PP2+?
    • #121732
      Yes the courtesy outlet is rated for max 200 W, so you should be fine.
    • #121738
      The fact that you say I "should be fine" troubles me… Will I be under warranty if I do and the pedal breaks?
    • #132968
      The  courtesy outlet seems like just another AC outlet with 200 W rating. So as long as you use the eventide power supply you should be covered under the warranty. You can contact voodoo lab regarding specifics about the power outlet.
