Home › Forums › Products › Stompboxes › Powering Space on PP2+ (international)
May 30, 2011 at 12:18 pm #107910
Hi guys, would love a solution to my problem.
I have purchased a Space from the US as it's much cheaper there, but I live in Australia. I own a PP2+ and need outputs 5/6 for other pedals so I can't use them with a Y cable to run the Space.
What I would love to do it power it from the PP2+ courtesy outlet. Now, the problem is that on the international PP2+ the courtesy outlet is a reverse IEC connection AC. Is it possible to some how power the Space via this IEC courtesy outlet? It would be hugely appreciated if you were able to help me out here!
One more short question before I go. This is unrelated to the first question. I bought the Space from the US I will get a US power supply, is a US > Australian power plug adapter suffice to connect it to the wall or would I need a completely new AUS power supply if I wanted to plug it into the wall?
Cheers!
Matthew.P.S. I am aware of the power factor power supply but unfortunately I cannot afford another power supply right now, so I need to try and make do with what I have got.
May 30, 2011 at 4:11 pm #122210
You'll have to either get a voltage converter, or get a Australian rated PSU. I have heard that *** Smith makes one that works. Im actually looking for a replacement one for my Modfactor as I either lost it at a gig(unlikely) or someone nicked it as I was packing up. I havent found anything on the net as to their availibility though.
Kind regards
Patric
May 30, 2011 at 10:17 pm #122212
Thanks for your reply Patric. So I will definitely need an Australian power supply regardless. That's ok, I'm sure I can find one at *** Smith or Jaycar.
I still need to figure out whether it is possible to power it from the reverse IEC connection of the PP2+.
Matthew.
June 1, 2011 at 9:45 pm #133471
Hey Matthew,
this is the sort of thing I was thinking of following our discussion over at TGP..
http://www.stayonline.com/detail.aspx?ID=6626
you could use something like this to plug into the courtesy socket on the PP2+ if you can find a PSU that accepts the fig8 (C7) connector.
would probably be better if it had a cable between the two connectors rather than a rigid all-in-one connector.
cheers
Martin
June 1, 2011 at 10:07 pm #133472
Thanks again Martin, I'll have a look into it.
Matthew.
June 2, 2011 at 8:10 am #133473
No worries mate, happy to help
June 2, 2011 at 3:43 pm #133476
You also might look at http://eventidestore.com/powersupplies1.html
June 15, 2011 at 2:54 am #133523
I can confirm that this works, adds no noise and is cheap for Australian customers, as Eventide wants to charge about 30 bucks for shipping a PSU that costs 19 bucks and weighs next to nothing. I find that a little disconcerting and uneeded
http://dicksmith.com.au/product/M9933/regulated-ac-adaptor-9vdc-800ma.jsp
June 15, 2011 at 2:50 pm #133524
Our power supply weighs 1 lb 1 oz before packing. The reason for the high shipping charge is that our company policy requires full trackability, so we use Fedex International. Since Australia is on the other side of the world, this is .. expensive. Sorry.
You could try harassing our new Australian dealer, Audio Chocolate in S.Yarra, Victoria. Maybe if enough people want power supplies they'd get some in.
June 15, 2011 at 9:54 pm #133528
Ok Fair enough, I spoke too soon. Sorry for that, my apologies
