I’m setting my H90 on pedalboard and I want to use 2 algorithms pre and post as dual routing mode, pre will be before overdrives and post will be after the delay.
I wonder if the h90 can handle the first route as mono and second one as stereo?
If I use only I/O 1 for path 1 as mono, and I/O 3&4 for path 2 as stereo, will H90 automatically configure itself?
Yes, you will have the correct mono/stereo behavior without any further configuration if you connect to Input/Output 1 for the first path, and Inputs/Outputs 3-4 for the 2nd path.
