Problem with dual routing
Home Forums Products Stompboxes Problem with dual routing
    • #194125
      albertoplen
        I have a Diezel Herbert Mk3, h90 works perfect in the loop, and works perfect in the input, but it doesnt sound anything if I connect in dual routing, 4CM mode (in/out 1-1, loop 3-3).
        Is there someting more I must do?
      • #194129
          Did you setup the H90 be in Dual Mode? https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/edit-modes/routing.html
          Full instructions for 4CM / Pre/Post mode can be found here: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/setup/pre-post.html
        • #194135
          albertoplen
            Thanks for replying.
            I don’t know what the problem was because I think I did the same thing as the previous 10 times, but now it works fine!
            The only thing is, I had to change the bypass type to Relay, which I’m not entirely sure what it does, but otherwise, the amp didnt sound work with the H90 deactivated, and with the”relay” mode, I have the amp, the preset in pre, and the preset in post. So, perfect!
            Cheers
