Problem with saving tape echo without saturation
Home Forums Products Stompboxes Problem with saving tape echo without saturation
    • #107642
      cristianfonseca
        the problem is that when you try to save tape echo without saturation it sound good but when you pass to another bank and use the effect when you turn back to the tape echo you will see that the tape echo has all saturation
      • #121578
        This is a known "bug" that has been posted several times. The TF appears to actually be saving the opposite value. Eventide has stated that this will be fixed in the next update.
