Problems with filter knob of the Classic Chorus H9
Home Forums Products Stompboxes Problems with filter knob of the Classic Chorus H9
    • #113329
      nacholaborde54
        Hello!
        Someone realized that do not properly filter knob of the Chorus Clasic? The sweep knob is very irregular and  changes the sound dramatic.
        I have the latest version of firmware h9 and  h9 Control latest version.
        Thanks in advance!
      • #142858
        gkellum
          Thanks for the feedback.  We'll check it out and see if we can reproduce what you're experiencing.
        • #142864
          gkellum
            We couldn't really reproduce the problem that you're describing.  The only case where we were hearing dramatic changes was if the Depth knob was turned all the way up.  If what you're hearing isn't related to that, you may want to restore your H9s system settings, as this might be related to that.  You restore the system settings by turning your H9 off and then turning it on again with the right footswitch and the HotKnob switch pressed (the knob in the upper left hand corner of the H9).  This was wipe out any changes you've made to your H9s system settings but won't affect your presets.
