Home › Forums › Products › Stompboxes › Question About Output Routing: OUT1 (Dry+Wet), OUT2 (Wet Only to Amp2)
- This topic has 4 replies, 3 voices, and was last updated 4 months, 2 weeks ago by
Kazuya_lillies.
June 18, 2025 at 10:09 pm #190658
I have a question regarding the output routing on the Eventide H90.
Is it possible to configure the outputs so that:OUT1 carries a mix of Dry + Wet signals
OUT2 carries Wet only (no Dry signal), which I plan to send to a second amp (Amp2)
My goal is to run a wet/dry rig, where OUT1 goes to my main guitar amp, and OUT2 (Wet only) goes to a second amp for the effects return.Currently, both OUT1 and OUT2 are outputting the same signal (Dry + Wet), but the delay effect alternates between the two outputs — indicating a stereo delay.
In this situation, I would like to keep the Dry + Wet mix on OUT1, and have OUT2 carry Wet only (no Dry).If this configuration is possible, could you please let me know how to set it up within the H90?
If not, is there any recommended workaround? -
June 19, 2025 at 5:15 pm #190666
There are a lot of unanswered questions about the routing ability of this device. It seams very overlooked by Eventide who could show all of us musicians who are not tech savvy a handful of possibilities. Currently I think they show just a few uses in the manual but I mean there are a lot of options I THINK. Can some of the inputs and outputs be used to run other pedals through just in a bypass mode so you can take advantage of your amplifiers single effects loop without placing those pedals before or after effects being used in the H90?
June 20, 2025 at 10:48 am #190672
Hi thejohnsupremo I’m not fully understanding what your question is.
You may use other guitar pedals in the insert path of the H90, instructions for that are here: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/setup/two-mono-inserts.html
You can have the inserts active when the H90 is bypassed by setting the Bypass mode to AB only: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/system-menu/global.html
June 20, 2025 at 10:46 am #190671
Outputs 1-2 will always be a stereo pair. You can follow the instructions from the manual for a wet/dry setup: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/setup/wet-dry.html
In that example, output 3 will be the dry signal and output 1 will be the wet signal.
June 21, 2025 at 4:23 am #190674
Thank you for the clarification.
I understand that outputs 1-2 are always treated as a stereo pair, and I appreciate the information about the wet/dry setup using Output 3 for dry and Output 1 for wet.
However, I personally would love to be able to route Dry + Wet to Output 1 and Wet-only to Output 2, so I can send a full mix to Amp1 and only the wet signal to Amp2.
I’m not sure if other users are looking for the same routing option, but I believe it could be very useful for players using two amps or stereo rigs with a wet/dry approach.
I’d be happy if this kind of flexibility could be considered for a future firmware update.
Thanks again for your support and for continuing to develop this incredible unit!
