Question:stompboxes in parallel
Home Forums Products Stompboxes Question:stompboxes in parallel
    • #108286
      Hello and Happy new year!
      I have setup my rig to run the 4 Eventide stompboxes in parallel,but i have one question…
      I like that i have my signal more cleaner and unmuddy with parallel connection than serial…
      but there are  algorithms like DynaVerb,Reverse,Synthonizer…that i don't want to have my dry signal all the time!
      any suggestions-solutions?
      Thanks,
      Nikos
    • #123005
      Hello!
      I forgot to write that i have those units in parallel,but in parallel with the dry signal!
      So,i have enabled the kill dry function and i have the dry signal in parallel with the Eventides all the time.
      What do you suggest me to do if i want to play with algorithms like DynaVerb,Reverse,Drop tuning,Synthonizer,PitchFlex…in which i don't want to hear the dry signal?
      Will the Output Level function to help this…?
      Thanks,
      Nikos
    • #123007
      MarcoR
        If I'm understanding correctly, I don't think there's an easy way to accomplish that.
        Killdry would have to be switchable and its not and then you would need
        an elaborate switching system to reconfigure your parallel routing.
        Is there any way to put your dry signal in a switcher that you could switch off?
