Rose expression pedal issue
Home Forums Products Stompboxes Rose expression pedal issue
    • #194054
      Danmusic1968
        Merry Christmas to all.
        My question is for some reason I can’t morph between A&B with my M-Audio expression pedal. In the past it just worked by default but for some reason I can’t get the morphing between A&B to work. I have followed instructions on YouTube and the manual but nothing is working. I own six M-Audio expression pedals and no positive results with any.
        Thanks in advance,
        Dan.
      • #194065
          To clarify, did you follow the instructions to set EXP JACK to expression pedal mode? https://cdn.eventideaudio.com/uploads/2021/09/Rose-QRG-Rv21.pdf
        • #194066
          Danmusic1968
            I will look back but I am pretty sure that I am on task.
            Will keep you informed.
            Cheers,
            Dan.
