Rose – minimum modulation rate
Home Forums Products Stompboxes Rose – minimum modulation rate
    • #194140
      Wardy66
        Haven’t had a Rose for a while but thinking of picking one up again.
        Can anyone tell me what the slowest modulation rate is please? In ms or tempo.
        is it related to the delay time set or independent?
        Thank you
      • #194155
          Postulating here, not theorem-tested.
          Ad copy says “Standard delay time from 10 seconds to 10 microseconds”, and “modulation sweep from 1/2 to 2x the standard delay time.”
          So, that would be 0.05-0.2 Hz. at 10 seconds.  The delay multipliers cut the sample rate.  I don’t recall if/how that plays into the modulation speeds.
          And on the lowest end of the delay scale, I doubt the modulation sweep exceeds the nominal sample rate (100K).  But who cares about any inexactness down there?  That is the delay area where those gorgeous modulation sweeps live & breathe.
        • #194158
          Wardy66
            Thanks Brock
            That sounds good – I was thinking of very long delays with slow square wave pitch shifting.
