Home › Forums › Products › Stompboxes › Rose Spillover or Trails/
- This topic has 6 replies, 3 voices, and was last updated 10 months, 1 week ago by
corbeano.
May 1, 2025 at 2:09 pm #189946
How do I get the Rose to have trails or spillover when I hit the active off?
And then,,,,,,, How to Rose the rose to have trails or spillover when using Exp Pedal for Mix?
Thanks for any info
May 1, 2025 at 3:00 pm #189951
We meet again, sir. How is your Bypass mode set up (Buffer / Relay / Input Kill / Kill-Dry)?
May 1, 2025 at 8:05 pm #189959
Hello there,,, yes, Is kill kill dry i believe,,,
The only one that will have a trail…
So i use that and then the exp pedal will not work with Mix.
Thanks for any info Brock
May 1, 2025 at 10:58 pm #189960
In your situation, I’m considering that Mix question at TGP, and that you’re probably running Rose front-of-amp. You don’t want Kill Dry (bottom / 5th LED lit in combination with any other LED in that ladder).
If you’re running sends & returns to a mixer, or parallel amp loop, that’s a different story, and another approach. But assuming my guesses are correct here …
There are actually 6 Bypass modes:
- Buffer (2nd LED)
- Buffer + Kill Dry (2nd & 5th LED)
- Relay (3rd LED)
- Relay + Kill Dry (3rd & 5th LED)
- Input Kill (4th LED)
- Input Kill + Kill Dry (4th & 5th LED)
ACTIVE + the PHI button for Bypass select mode. Press PRESET to cycle through the 6 choices (the 1st / top LED isn’t involved here). Try out the 2nd, 3rd & 4th LED positions. Make sure that bottom / 5th LED stays unlit. Press Active to lock in the setting.
Now your EXP -> MIX mapping (earlier post) should work. As for the spillover / trails … I’m not sure if you meant using the MIX mapping, or when Rose is bypassed. Mix is positioned after all the delay processing, so you cut out the trails when you pull back to dry.
Bypass mode is the default (2nd LED). I believe your best bet is Input Kill (4th LED). One thing you might notice in Bypass … the delay structure is still running underneath.
May 2, 2025 at 6:33 am #189964
Good morning,,,
Thank you for all your help,,, It is really appreciated..
Ive tried every which way to get this to work for me. I finally gave up on the Rose.
I love the core sound,,, but that silly manual and interface is too smart for me.
I had time to mess with it yesterday to really dial the pedal in and its just not going to work…
It took me less than 5 minutes to do exactly as needed on the Timeline. It’s a no brainer.
Maybe Eventide will come up with a better/intuitive interface for others like myself someday.
Thanks again you help,,, I will put the Rose on back burner for some other use someday, or sell it. This is the 3rd attempt for live applications.
I erased the Thread on TGP,
Regards,
Corbin
May 2, 2025 at 12:13 pm #189973
Sorry for the issues your having. You want the “input kill” setting for the tails to ring out when your bypass the Rose.
I’d suggest using the EDM app to adjust these settings. That has a pretty simple interface for adjusting all of the settings, and once you have it set how you like you don’t need to revisit the app. Just make sure to click the arrow in the top right corner to send the settings change to the device.
May 2, 2025 at 1:04 pm #189976
Don’t be sorry at all,,,, Its prob user error,,, But Ive dowe what you and Brock mentioned and have trouble with the exp pedal not giving me mix parameter.
Ive reset the pedal… I spent almost four hours yesterday with it… I had minor breaks in-between,… but damn… Should not be this difficult I
would think,
There are others that get along just fine with the Rose and its crazy interface.. I feel that It is beyond be me at this point.
Kind of like Jazz, It took me a bit to come around and understand it and start working on it. All good,
Maybe I will try again next year.
Corbin
