Rose Volume Boost
Home Forums Products Stompboxes Rose Volume Boost
    • #116304
      stark
        Input switch set to guitar, Bypass set to Relay, there is a big volume boost on bypass. Bypass set to Buffer, predictably both In/Out are boosted no level difference. Any way to adjust the gain to match the Relay Bypass?
      • #156895
        joecozzi
          Are you going into a guitar amp or a line-level device? Typically, when you experience a volume difference when in Relay mode it's because there's an impedance mismatch between the "Guitar" signal and the input of the device. This can also happen if the cable from the pedal to the amp is very long.
          To answer your question, other than the line/guitar switch, there's no way to adjust the gain to match. You would have to use a preamp in between the pedal and the input of your next device.
        • #156896
          stark
            Right into amp, no other pedals. I understand the pedal buffer will effect the signal, but there still is a significant gain boost. Cable length is not an issue.
