Rotary Algorithm pitch modulation depth
Home Forums Products Stompboxes Rotary Algorithm pitch modulation depth
Viewing 0 reply threads
    • #114639
      llemtt
        although a true impersonation of a leslie cabinet, I find the pitch modulation of the Rotary Algorithm a little bit too much at slow settings and not good sounding at all at high speed: on guitar higher octave notes it almost becomes a sort of ring modulation sound…
        Playing low register notes it’s ok, and mid register chords sound good but very “hammond sounding”, not always a good thing if you are in search for a “cold shot” kind of sound.
        Is there a way to reduce the (primary) modulation depth? I see that I can “modulate the modulation depth” with the lower controls but I can’t understand how I can just reduce it a bit.
        Many thanks.
