Saving program tempo on H90 pedal
Home › Forums › Products › Stompboxes › Saving program tempo on H90 pedal
Viewing 4 reply threads
    • #167820
      ed536m
        Where can I save tempo change for a program on the pedal.
        thanks
        Ed
      • #167821
          You can press the Presets and Parameters buttons together to access the Tempo menu. If Source is set to Program, then your Program will always load with the BPM value it was saved with.
        • #167822
          ed536m
            Ok then how do I change the tempo on the program?
          • #167823
              Adjust the BPM from the Tempo Menu using Quick Knob 1, then save the Program.
              All of the tempo operations are explained here: https://cdn.eventideaudio.com/manuals/h90/1.1.4/content/tempo-menu.html
            • #170466
              Lightborne
                How do you set the tempo for a program from the H90 control software?
