scales pitch factor
Home › Forums › Products › Stompboxes › scales pitch factor
Viewing 4 reply threads
    • #106805
      dink1
        hello,
        i have two pitch factor,one is on two auxiliary and one from the outpout of the mix.
        i play guitar with only bottle neck and a sing thrue the pitch factor.
        i've a problem with the scale, maj, minor,etc because i play often out of tune, and the  pitch factor gives me the correction.
        i need to have a normal pitch without the scale.
        and from the output of the mix there is a lot of armony disonance etc,and the pitch factor give something with the correction and it skip.is it possible to turn off the scale?
        i had try a boss pitch shifter ps5 and it's works with this one.
        i don't know how to do.to have the texture of sound without scale.pitch noise for exemple.
        i'm sorry for my english,i'm french.
        thanks a lot.
      • #119837
        achaput
          Try the Harmodulator effect. It can change pitch +/- 3 octaves and is NOT scale-based; it is chromatic.
        • #122253
          dafonk
            Can the pitchfacor harmoniser handle pentatonic scale or blues scale ?
            If yes, how to configure it ?
            Thank you
          • #133497
            badmelonfarmer
              No, not unless things have chenged in the latest release.
            • #133502
              roverdog
                It can sort of handle the major and minor penatonic scales if you set either major or minor and then only use the 5 notes(1, 3, 4, 5, 7 for minor; 1, 2, 3, 5, 6 for major  ).  Thats how I get around it
                Steve
